futelihut
Apr 04, 2019Aspirant
IPv6 DHCPv6 Prefix Delegation
Hi
My ISP requires Prefix Delegation for IPv6 support.
Is there a way to configure the RBK50 router to fetch prefix delegation from my ISP?
Or is it not supported?
/Morten
futelihut
Apr 05, 2019Aspirant
Thanks for the reply, i will try contacting NG support
/Morten
timch
Apr 05, 2019Luminary
What is your ISP. I have my system working fine with BT in the UK and that requires PD.
- futelihutApr 05, 2019Aspirant
Hi
Kviknet in DK.
How have you configured your IPv6 settings?
/Morten
- Random12Apr 05, 2019Apprentice
The prefix delegation bit isn't anything special, I believe you select DHCP as the IPv6 WAN connection type and it should be automatic.
Regards
- timchApr 05, 2019LuminaryThese are my settings but as stated above, I didn’t do anything fancy, it just worked but I know BT uses PD.
