futelihut
Apr 04, 2019Aspirant
IPv6 DHCPv6 Prefix Delegation
Hi
My ISP requires Prefix Delegation for IPv6 support.
Is there a way to configure the RBK50 router to fetch prefix delegation from my ISP?
Or is it not supported?
/Morten
futelihut
Apr 05, 2019Aspirant
Hi
Kviknet in DK.
How have you configured your IPv6 settings?
/Morten
Random12
Apr 05, 2019Apprentice
The prefix delegation bit isn't anything special, I believe you select DHCP as the IPv6 WAN connection type and it should be automatic.
Regards
- timchApr 05, 2019LuminaryThese are my settings but as stated above, I didn’t do anything fancy, it just worked but I know BT uses PD.
- futelihutApr 05, 2019Aspirant
Hi
Thanks for the reply. My ISP do not support PPPoE, they uses direct connection.
From the information I have been given, the router must support prefix delegation over DHCP. But setting it to DHCP do nothing.
I will try to contact NG support
/Morten
- ekhalilApr 07, 2019Master
Orbi supports prefix delegation.
Please check th configuration below:
root@RBR50:/etc# cat dhcp6c.conf
interface wanifname {
send ia-na 1;
send ia-pd 11;
request domain-name;
request domain-name-servers;
request ntp-servers;
request sip-server-domain-name;
request sip-server-address;
script "/etc/net6conf/dhcp6c-script";
};id-assoc na 1 {
};id-assoc pd 11 {
root@RBR50:/etc#DHCPv6 prefix delegation operates as follows:
- A delegating router (Server) is provided with IPv6 prefixes to be delegated to requesting routers.
- A requesting router (Client) requests one or more prefixes from the delegating router.
- The delegating router (Server) chooses prefixes for delegation, and responds with prefixes to the requesting router (Client).
- The requesting router (Client) is then responsible for the delegated prefixes.
- The final address allocation mechanism in the local network can be performed with SLAAC or stateful/stateless DHCPv6, based on the customer preference. At this step the key thing is the IPv6 prefix and not how it is delivered to end systems.
