RedBatman89
May 21, 2022Guide
ipV6 disconnecting
Funny I myself have been dealing with this issue for the Past Year. I have an RBK23 and Xfinity Internet.
RedBatman89
May 21, 2022Guide
I have had similar issues myself since 2021. I have an RBK23 and Xfinity too, but instead of every other hour its once a week or every five days. When you updated firmware did you factory reset?
cdysthe
May 22, 2022Virtuoso
RedBatman89 I have factory reset several times. Doesn't help. I used to have it drop every few hours. Then I upgraded firmware and now it drops every 5-7 days. Improvement, but not how it should work.
- cdystheMay 22, 2022Virtuoso
P.S. Speaking of the devil, it just happened again. I have currently not been able to get a new IP even after reboot. And I am NOT going to do another factory reset so I will keep toggling off, disable DHCP until I get an IP for another 5-7 days.
P.P.S:I have noticed though since I've done this weekly for months that if I wait 5 minutes after disabling, auto detect and DHCP I am more likely to get an IP that if I do it in quick succession.
- RedBatman89May 27, 2022GuideWell good to know that factory reset can only do so much I was thinking of doing one myself after an update.
- FarmerBob1Jun 11, 2022Luminary
On my RBR853 I lost IPv6 solidarity when a change was in the FW that made the WAN IPv6 IPA, that told me that I was getting and Address off the WAN, disappear from the second line in the WAN set up area as one shows in the LAN. This was quite a while ago, FW v3.x and we're at v4.6.x, and since it's been hit or miss.
This was during a Beta Test so "the powers that be knew about it" and it's been a newer and growing issues everywhere it can be talked about and is being posted all over. And it seems that it's certain product lines. With my RAXE500 IPv6 has been pretty solid holding on to it.
Soon I hope . . .
