RedBatman89
Dec 14, 2020Guide
IPV6 Needs fixing again.
So I still have my rbk23 and I have to say that since frimware 2.5.1.16, there have been some IPV6 issues again. The couple of previous firmwares seem to have fixed it before but now on some machines...
Dec 19, 2020Guru - Experienced User
Be sure it's NOT an ISP or IPv6 configuration issue first as it may not be a FW issue.
RedBatman89 wrote:So I still have my rbk23 and I have to say that since frimware 2.5.1.16, there have been some IPV6 issues again. The couple of previous firmwares seem to have fixed it before but now on some machines it will say IPV6 Not availiable, while others it will be okay. The Windows computers in the houshold seem to be the most affected. If one machine has IPV6 availiable but the other one doesn't then if I restart on of them the IPV6 will be availbe for the one that didn't have it prevosily. Oddly even though it says unavailible the IPV6 adressses still appear. Now my Linux machines seem unaffected by this, as well as any android, iphone, or game consoles devices so far. I upgraded the firmware to 2.6.1.36 to see if that fixed it but after a week it happened again. At first I tought it was Comcast since they are my ISP, but given the oddity of this issue I think its more of a firmware thing. Please fix this Netgear.
RedBatman89
Dec 26, 2020Guide
Well I tried adjusting the settings and so far it hasn't done it again. But I haven't restarted my Windows PC in almost 2 weeks so there is that too. I think Netgear needs to tweak thier next firmware update a little.
- FURRYe38Dec 26, 2020Guru - Experienced User
Something to contact NG support about then.
Good Luck.
