devdeep
Sep 03, 2022Guide
IPV6 setting options
Currently the IPV6 is set to "disabled". I want to turn this on but not sure of the right option. The options given on drop down menu are: Auto detect, Auto Config, 6to4 Tunnel, 6rd, Pass Through...
- Sep 03, 2022
Try auto-detect.
what modem/gateway is it connected to?
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
Sep 03, 2022Guru - Experienced User
Try auto-detect.
devdeep
Sep 03, 2022Guide
Connected to Virgin Media. Planning to move to Sky FTTP ONT route. I have read that Virgin does not support IPV6
- michaelkenwardSep 05, 2022Guru - Experienced User
Not much point in enabling it then.
If my experience on BT's network is anything to go by it can bring your network to a grinding halt.
- devdeepSep 05, 2022Guide
devdeep wrote:
Not much use now with Virgin, but as I said, planning to move to Sky.
So, be prepared for problems if you enable IPv6 on a network that doesn't support it.
