OrbiMan
Apr 06, 2018Luminary
Is 2.1.3.4 in auto update.
AmitR I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI. Orbi Product Management However I check my Orbi it is not showing...
Apr 06, 2018Guru - Experienced User
Even after selecting for check update?
You can manually update as well. Please do a factory reset on both router and satellite(s) then set up from scratch if you upgrade the FW.
I recommend using IE11 or FF browsers for this. Be ethernet wired with the router and satellite when doing the update. Update the Satellite first, then router.
OrbiMan wrote:
AmitR
However I check my Orbi it is not showing the update. Mine is still 2.1.2.18
- tagteamApr 06, 2018Virtuoso
For some reason, NG does not have v2.1.3.4 listed in the RBK53 product.
See http://www.netgear.com/support/product/RBK53.aspx#download
