OrbiMan
Apr 06, 2018Luminary
Is 2.1.3.4 in auto update.
AmitR I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI. Orbi Product Management However I check my Orbi it is not showing...
Apr 06, 2018Guru - Experienced User
Even after selecting for check update?
You can manually update as well. Please do a factory reset on both router and satellite(s) then set up from scratch if you upgrade the FW.
I recommend using IE11 or FF browsers for this. Be ethernet wired with the router and satellite when doing the update. Update the Satellite first, then router.
OrbiMan wrote:
AmitR
However I check my Orbi it is not showing the update. Mine is still 2.1.2.18
tagteam
Apr 06, 2018Virtuoso
For some reason, NG does not have v2.1.3.4 listed in the RBK53 product.
See http://www.netgear.com/support/product/RBK53.aspx#download
