OrbiMan
Apr 06, 2018Luminary
Is 2.1.3.4 in auto update.
AmitR I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI. Orbi Product Management However I check my Orbi it is not showing...
tagteam
Apr 06, 2018Virtuoso
OrbiMan wrote:
However I check my Orbi it is not showing the update. Mine is still 2.1.2.18
Mine is not showing either (RBK53) and I have checked in the UI several times with different browsers.
Funny thing is it was showing several days ago and I just figured it would auto-update as per usual. However, they auto-update never did happen and now the UI shows no new firmware version. I'm still on v2.1.2.18, which is fine since I have zero issues with it.
Retired_Member
Apr 06, 2018i still don't have 2.1.3.4
- loomis1975Apr 06, 2018Luminary
They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
I didn't have any real issues with 2.1.2.X, so I waited till 3 of my 4 devices had beta firmware available for them before I tried it out.
My RBS50Y is still on 2.1.2.20, but seems to be working fine with the rest of the things on the latest beta, 2.1.3.X
- tagteamApr 06, 2018Virtuoso
loomis1975 wrote:They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
Yeah, my point was that it is just awfully strange that v2.1.3.4 appears on the download page for RBK50 but not for RBK53 nor RBR50. The only reasonable presumption is an oversight.
I think you are right. When they pulled 2.1.3.4 off auto update, they should have pulled it off the RBK50 product page as well.
