OrbiMan
Apr 06, 2018Luminary
Is 2.1.3.4 in auto update.
AmitR I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI. Orbi Product Management However I check my Orbi it is not showing...
Anonymous
Apr 06, 2018i still don't have 2.1.3.4
loomis1975
They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
I didn't have any real issues with 2.1.2.X, so I waited till 3 of my 4 devices had beta firmware available for them before I tried it out.
My RBS50Y is still on 2.1.2.20, but seems to be working fine with the rest of the things on the latest beta, 2.1.3.X
- tagteamApr 06, 2018Virtuoso
loomis1975 wrote:They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
Yeah, my point was that it is just awfully strange that v2.1.3.4 appears on the download page for RBK50 but not for RBK53 nor RBR50. The only reasonable presumption is an oversight.
- loomis1975Apr 06, 2018Luminary
I think you are right. When they pulled 2.1.3.4 off auto update, they should have pulled it off the RBK50 product page as well.
- DarrenMApr 11, 2018Sr. NETGEAR Moderator
You can find the links to the firmware here in this thread
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584
Right now the firmware is not on the auto update sever until the engineers agree it is completely ready to be pushed to all systems.
DarrenM
- AnonymousApr 11, 2018
DarrenM wrote:You can find the links to the firmware here in this thread
DarrenM
Does Netgear recommend a factory reset after a auto-update to the new FW?
- DarrenMApr 17, 2018Sr. NETGEAR Moderator
If you are experiencing issues yes I suggest a factory reset.
DarrenM
- AnonymousApr 17, 2018
DarrenM wrote:If you are experiencing issues yes I suggest a factory reset.
DarrenM
thanks.....so when is 2.1.3.4 in auto update.???
