Pinhigh07
Jan 28, 2019Follower
Is 72 mbps the best I can hope for on 2.4 ghz? If not, how do I increase the speed?
The highest mbps I’ve gotten is 72 on the 2.4 ghz channel. I’m using it for a NordicTrack x22i that uses a 1080 screen for workout videos. It will not connect to the 5 ghz where my speeds are grea...
Jan 28, 2019Guru - Experienced User
You'll need to check with the Mfr of the wifi adapter on the NordicTrack to see what connection rates it supports. Not all adapters support higher connection rates. Orbi supports up to 600mb connection rates on 2.4Ghz.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz.
What WPA security modes are you using? Try WPA2 and AES only.
