Pinhigh07
Jan 28, 2019Follower
Is 72 mbps the best I can hope for on 2.4 ghz? If not, how do I increase the speed?
The highest mbps I’ve gotten is 72 on the 2.4 ghz channel. I’m using it for a NordicTrack x22i that uses a 1080 screen for workout videos. It will not connect to the 5 ghz where my speeds are grea...
Ragar99
Jan 29, 2019Luminary
MU-MIMO dos NOT affect the 2.4 GHz throughput.
ekhalil
Jan 29, 2019Master
Thanks, you are absolutely right. 2.4 GHz supports only SU-MIMO and not MU-MIMO. This parameter in the advanced wireless settings in the web GUI is only for MU-MIMO. I confirmed this by checking the config parameters:
wla_mu_mimo=1
wlg_mu_mimo=1
wla_2nd_mu_mimo=1
So this parameter only affects the 5Ghz channels for the fronthaul's main wifi channels (wla) and the guest wifi (wlg) and has nothing to do with the 2.4GHz channel (wl). :)
