Pinhigh07
Jan 28, 2019Follower
Is 72 mbps the best I can hope for on 2.4 ghz? If not, how do I increase the speed?
The highest mbps I’ve gotten is 72 on the 2.4 ghz channel. I’m using it for a NordicTrack x22i that uses a 1080 screen for workout videos. It will not connect to the 5 ghz where my speeds are grea...
Jan 29, 2019Guru - Experienced User
Please let us know if you have any progress on this and let us know what the Mfr says about the connection rates your device supports.
Pinhigh07 wrote:
The highest mbps I’ve gotten is 72 on the 2.4 ghz channel. I’m using it for a NordicTrack x22i that uses a 1080 screen for workout videos. It will not connect to the 5 ghz where my speeds are great.
Any way to pump up the 2.4 speed? Thanks!
