elmnoise
Mar 31, 2023Aspirant
Is a Factory Reset Sufficient to Resolve Suspected System Compromise?
My question: I'm concerned that my Orbi was compromised/hacked. If I do a factory reset is that "sufficient" to resolve a security incident? My gut is to throw the devices out because I don't know en...
Mar 31, 2023Guru - Experienced User
Yes.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
