elmnoise
Mar 31, 2023Aspirant
Is a Factory Reset Sufficient to Resolve Suspected System Compromise?
My question: I'm concerned that my Orbi was compromised/hacked. If I do a factory reset is that "sufficient" to resolve a security incident? My gut is to throw the devices out because I don't know en...
elmnoise
Apr 01, 2023Aspirant
Hello. The AT&T Gateway is the Pace 5268AC. I set it up to open a "pinhole" to the RBR50. The RBR50 is on a 10.X network, and the Pace is on the normal 192.168.X. I've had this configuration for a couple of years without issue. I agree it's not necessarily a problem with the Orbi, but that's where the errors were coming from. I factory reset everything and ensured the latest firmware was applied. No problems now, but still a bit nervous about using this Orbi.
Apr 01, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
I would try option #2 first or if your overly conserned, try option #3 and let the ISP gatway handle security.
