peterg09's avatar
peterg09
Follower
Mar 09, 2021
Is a modem required to connect ORBI to a Internet provider
I understand that ORBIs do not include modems, but are modems necessary to connect ORBI to the Internet coming into the house?  When is a modem necessary and when is it not required?  If it matters, ...
  • CrimpOn's avatar
    Mar 09, 2021
    peterg09 wrote:
    I understand that ORBIs do not include modems, but are modems necessary to connect ORBI to the Internet coming into the house?  When is a modem necessary and when is it not required?  If it matters, I will be an Xfinity Internet customer and the ORBI is the RBK753S from Costco.  Thank you.
    There must be some device that can be connected to the Orbi WAN (yellow) port to provide a conversion between the Internet Service Provider (ISP) network and the Orbi router.  For cable (coax) systems, it is called a "modem".  If the ISP network is fiber, it often a "fiber Optical Network Terminator (ONT)."
    My guess is that Xfinity is a cable system.  Customers have the option of renting a modem from the ISP or purchasing their own from the list of supported cable modems on the ISP support web site.
    Hope this helps.
