swrtwdrv's avatar
swrtwdrv
Apprentice
Jan 04, 2017
Is Backhaul also using 2.4GHz?
I have my Orbi 2.4GHz Channel set to 11. Using either inSSIDer Home or WiFi Commander, I see the signals form the Orbi router and each of my Satellites on channel 11. At about the same signal strengt...
  • swrtwdrv's avatar
    swrtwdrv
    Jan 17, 2017
    Nothing from the Netgear engineers yet, so I assume they haven't figured out what is going on with my Orbi.  Looking at some of the debug logs, the SSID of the hidden 2.4GHz signal is identical to the SSID of the backhaul on 5GHz.  Returned my Orbi to Costco.
