PurplePJ
Apr 29, 2021Guide
Is hardwiring satellites the answer to my woes?
I've installed a Savant home automation system that communicates with its remote control via the home's wifi network. The base system stays "awake" and thus quickly drains the battery on the remote....
- Apr 30, 2021
Here's the latest... we tried option 1 which was:
1) Charge all 3 to 100%, lay next to each other overnight, and check battery levels in the morning. He's only used one of the remotes thus far and claims it dies 2-3 hours after being off the charger. We are going to confirm the other two behave the same. If only one dies then it's a faulty remote.
This morning, all three were at 100%. He laid them side by side and came back three hours later. The suspect remote had a dead battery and the other two were at 100%.
So -- looks like he has a faulty remote.
Thanks!
P
PurplePJ
Apr 30, 2021Guide
They are REM-4000
PurplePJ
Apr 30, 2021Guide
Thanks!
P
- FURRYe38Apr 30, 2021Guru - Experienced User
Please mare your thread as solved so others will know.
Enjoy.
