DavidBroadway
Nov 25, 2020Aspirant
Is it not unbelievable?
Why on earth does it not say ANYWHERE that this product will not work if your broadband is delivered to your house by DSL? The wasted time and distress in trying to get this product to work and f...
Nov 25, 2020Guru - Experienced User
Probaby due to the fact that Orbi does work with DSL. There is a modem that is needed that the Orbi needs to connect to.
Your ISP should be able to help you out on how to get the DSL modem to work with RBR.
There is also the User Manual and Installation Guides to help as well.
DavidBroadway
The point is that it is not made clear that a separate modem is required!
