DavidBroadway
Nov 25, 2020Aspirant
Is it not unbelievable?
Why on earth does it not say ANYWHERE that this product will not work if your broadband is delivered to your house by DSL? The wasted time and distress in trying to get this product to work and f...
DavidBroadway
The point is that it is not made clear that a separate modem is required!
Nov 25, 2020Guru - Experienced User
"What Do I Need for Orbi to Work?
• High-speed Internet connection
• Connect to existing modem or gateway" <Would be all inclusive of cable or DSL or ONT or otherwise.
https://www.netgear.com/images/datasheet/orbi/RBK50.pdf
Starting at Pg 24 has all kinds of information about connecting Orbi to ISP services:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Sometimes you need some direction is all.
Good Luck though.
