marybhendrix
Mar 29, 2020Aspirant
Is it possible to connect my Orbi AC 2200 RBK20W wirelessly to my ISP Gateway (modem/router)
First let me explain that I own the Orbi AC 2200 RBK20W, but it isn't showing in the drop down menu for "model" so I chose the closest model RBK53 because it forced me to enter something on the list....
Mar 30, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
marybhendrix wrote:First let me explain that I own the Orbi AC 2200 RBK20W, but it isn't showing in the drop down menu for "model" so I chose the closest model RBK53 because it forced me to enter something on the list.
I successfully installed the Orbi router by connecting to my ATT Gateway using the enclosed ethernet cable. I then installed the satellite and both appear to be working.
I updated the firmware to the latest version as part of the installation process.
Is it possible to connect the Orbi router to the Gateway wirelessly instead of using an ethernet cable? That is what I thought I was purchasing, but now I am wondering if I have the wrong model. I would like for the router to be in a different location (essentially using it as a satellite) to cover all dead spots, and I don't want a 50 foot ethernet cable running between the Orbi router and ATT Gateway.
If this model is not capable of connecting wirelessly, would you please tell me which Orbi model would connect wirelessly?
If there is none, could I just buy two satellites instead of the router/satellite combination and connect those directly to the ISP Gateway? Two satellites or extenders is really what I need, not another router.
I read on one thread about changing the router to AP mode, but it never mentioned disconnecting the ethernet cable, so I am not sure if that is applicable here or not?
Thanks so much for your help,
Mary
