Spawn3D
Mar 02, 2020Tutor
Is it possible to connect one satellite wired and the other through Wifi
Since couple days I own a RBK53v2 Mesh Wifi system. One of my satellites has sometimes poor connection (it even connects on 2.4GHz time to time) to avoid bad connection on this satellite, I have...
theoak
Mar 02, 2020Luminary
Did you view the recommended wiring and ensure you have the router connected to the satellite on the correct ports?
Spawn3D
Mar 02, 2020Tutor
Yes like I mentioned on my first post, there is only one satellite connected, on port one (directly next to the yellow WAN port) at RBR50 and on port one directly next to SYNC button at RBS50.
