Spawn3D
Mar 02, 2020Tutor
Is it possible to connect one satellite wired and the other through Wifi
Since couple days I own a RBK53v2 Mesh Wifi system. One of my satellites has sometimes poor connection (it even connects on 2.4GHz time to time) to avoid bad connection on this satellite, I have...
Spawn3D
Mar 02, 2020Tutor
Thanks for the suggestions, I have been bussy last 30 minutes running between the satellites and the router, checked the cable with a network tester and everything seems to be okay.
Just before I perform a factory reset rebooted everything and now it suddendly connected through the wire. I am a happy with the setup now, it was bugging me a little.
Just to give you a idea, we have 3 floor house, at first floor I have the router and sateliets are on each other floor. All 3 mounted with a 3D printed holders.
The router is taken out the closet where the modem and other electronics devices are, it was getting hot in the closet in the summer months, so I hope this helps.
https://i.imgur.com/GfrP2rQ.jpg
Once again thanks for the help.
Mar 05, 2020Guru - Experienced User
Hope it's working well. if so, be sure to do a back up configuration to file on the RBR for safe keeping. Saves time if you have to reset the RRR in the future.
Spawn3D wrote:Thanks for the suggestions, I have been bussy last 30 minutes running between the satellites and the router, checked the cable with a network tester and everything seems to be okay.
