philtully's avatar
philtully
Is it possible to connect RBS50Y to either an RBR50 and/or RBS50 using Ethernet backhaul connection
I currently have an RBR50 base and 2 RBS50 Satellites connected with wired ethernet backhaul connections.  I would like to add an outdoor RBS50Y in the same method.    Is this supported?   I unde...
  • CrimpOn's avatar
    Jan 05, 2021
    The RBS50Y has no ethernet jack.  Wired ethernet backhaul is impossible.
