philtully
Jan 05, 2021Aspirant
Is it possible to connect RBS50Y to either an RBR50 and/or RBS50 using Ethernet backhaul connection
I currently have an RBR50 base and 2 RBS50 Satellites connected with wired ethernet backhaul connections. I would like to add an outdoor RBS50Y in the same method. Is this supported? I unde...
philtully
Jan 06, 2021Aspirant
Thanks for the info...I was still looking at solutions for my outdoor wifi access.
It looks like a weather proof case for a RBS50.
CrimpOn
Jan 06, 2021Guru - Experienced User
philtully wrote:Thanks for the info...I was still looking at solutions for my outdoor wifi access.
You might send a private message to Mstrbig (by clicking on his screen name). He has posted several times about installing satellites outdoors with enclosures. I do not recall seeing reference to any specific products or where he got them.
Such as this post: https://community.netgear.com/t5/Orbi/Looking-for-Outdoor-POE-Extension-for-Orbi-Mesh-in-Home/m-p/1970121
As you can tell from the messages, it is often more convenient to install outdoor access points that get power over the ethernet cable (PoE).
Good Luck
- philtullyJan 06, 2021Aspirant
I plan to mount this on the outside wall of my house so I can pass through power and ethernet
Thanks for your assistance
Mstrbig sent me this link to boxes: Amazon.com : weatherproof router box
