Rage91
Nov 17, 2019Aspirant
Is it possible to Daisy Chain my RBR20 satellite with newer model satellites?
Hello, I previously purchased the Netgear RBK20-100UKS Orbi AC2200 Starter kit which contained a router and satellite. *Model - RBR20 However, I realised afterwards that I require an additiona...
- Nov 17, 2019
Yes, you can. Additional satellites can be attached to your router, either in a "star" configuration where the new satellite connects directly to the router or in a "daisy chain" where the new satellite attaches to an existing satellite. Orbi will figure out which connection "works best" by itself. Bummer that your choices are limited to only the most expensive.
CrimpOn
Nov 17, 2019Guru - Experienced User
Rage91
Hi CrimpOn
My thanks for the swift response to the topic question. :smileyhappy:
It willl be nice to be able to have a decent network connection in the house at last.
And yes it does stink a little to be limited by the choice, as my only other option would be to get another starter kit to reuse the satellite, but that is more expensive than buying the newer model satellite.
Cheers.
