conker89
Feb 18, 2020Aspirant
Is it possible to split the 2.4ghz and 5ghz networks on the Orbi
Hi All I've been advised that to make my Firestick work more efficiently when streaming on it, I should force it to connect to the 5ghz network. Is there a way to force the Firestick to do this, I...
Feb 21, 2020Guru - Experienced User
Any progress on this?
conker89 wrote:Hi All
Is there a way to force the Firestick to do this, I've read that you can set up a 2.4 and 5ghz network, but the article was 3 years old.
My relatively limited knowledge of this is that the devices will bounce between networks, if this is the case, I'm tyring to nail it down to 5ghz.
Thanks
