conker89
Feb 18, 2020Aspirant
Is it possible to split the 2.4ghz and 5ghz networks on the Orbi
Hi All I've been advised that to make my Firestick work more efficiently when streaming on it, I should force it to connect to the 5ghz network. Is there a way to force the Firestick to do this, I...
gomerkyle
Feb 21, 2020Aspirant
It's important to know which Amazon device you are using as well as which content you're expecting to stream. Finally, is there a problem to begin with? Let me address the obvious one first. Do you have a problem with buffering at all? Have you noticed a "spinning wheel of death" ,or a loading pinwheel, at video start times? If there is no problem, strengthening the signal will offer no realized gains for you at all. As far as the device and content expected goes; if you have a 4K capable device plugged into an HDR television, that content (proper high definition, not YouTube's "4K" resolution videos) may demand upwards of 35Mbps. If we use the speed that most people are familiar with, Megabytes per second (MB/s) rather than Megabits per second (Mbp/s), that's just under 5 Megabytes per second. Not only is that well within 2.4Ghz frequency capability, but a mechanical USB 2.0 hard drive can keep up with that speed over the network as well.
There's no reason at all you would need to prefer one frequency band over the other unless you are reaching the maximum range of the much shorter, but stronger, 5Ghz band (there is also the possibility that if you were on the 2.4Ghz band and were encountering an incredible amount of interference, in which case you'd require a stronger radio broadcast in order to take advantage of the 5Ghz band). In that case the signal strength would drop below a set threshold configured in your device and adapt itself to the appropriate band to maintain the signal strength above that threshold. In network devices that do broadcast separate SSIDs, that would not be the case, and you would have to select one or the other. If you find that you are experiencing issues, do as another has mentioned and try and minimize the distance between the Fire stick and the network, and do what you can to mitigate the amount of solid obstacles between their line of sight. If you still have trouble and you can't move the devices any closer, you'll need an additional access point to expand the coverage of your network unfortunately.
conker89
Feb 25, 2020Aspirant
Hello. I'm using a 4k firestick for streaming, it's plugged into the back of the TV and is around 1-2 metres from the Orbi satellite, which is in a cupboard. I've been struggling with buffering on some of the services that I run, but not all. I was advised via a Firestick community page that ensuring the Firestick is on 5ghz would decrease buffering potential as fewer devices should be using this channel.
- FURRYe38Feb 25, 2020Guru - Experienced User
What FW version is currenlty loaded?
Separation of SSID on Orbi isn't supported.
What is the distance between the Orbi and the firestick?
Try turning down the 2.4Ghz power on the RBR and see if the firestick will connect to the 5Ghz radio. Under Advanced Tab/Advanced Settings/Wireless Settings. Also Set 20/40Mhz Coexistence to 40Mhz only.
conker89 wrote:Hello. I'm using a 4k firestick for streaming, it's plugged into the back of the TV and is around 1-2 metres from the Orbi satellite, which is in a cupboard. I've been struggling with buffering on some of the services that I run, but not all. I was advised via a Firestick community page that ensuring the Firestick is on 5ghz would decrease buffering potential as fewer devices should be using this channel.
- CrimpOnFeb 25, 2020Guru - Experienced User
WiFi does not "do well" when passing through metal objects. My first step would be to purchase an HDMI extension cord so that the Firestick can be moved to a location where it has a clear "line of sight" to the satellite. Did the Firestick come with an extension cord, as in this picture: https://troypoint.com/fire-tv-stick-4k-review/
