Ahwman's avatar
Ahwman
Is it possible to use satellite just as a switch?
Hello,
I no longer need my Orbi as a mesh system, however I would like to continue to use the satellite as a gigabit switch.  Will it continue to function (only as a switch of course), if I remove the router?
Thanks...
  • CrimpOn's avatar
    CrimpOn
    Ahwman wrote:
    I no longer need my Orbi as a mesh system, however I would like to use the satellite as a gigabit switch.  Will it continue to function (only as a switch of course), if I remove the router?
    For certain WiFi will no longer function.  Please give it a try and report what happens. It certainly cannot harm the satellite.
    I much prefer my inexpensive gigabit switches.  8 ports for under $30 and very small.
    • plemans's avatar
      Plus it uses a lot less power with a simple switch versus using a satellite as a switch. :)
