thebadpete
Aug 09, 2021Guide
Is it safe to downgrade Orbi firmware from 2.7.3.22 to older ones?
My Orbi RBR50 was on older firmware (2.3.5.30) and I manually disabled auto-updates and splitted the SSID's to discreet 2.4GHz/5GHZ's. This was due to some of my devices being old For some reason, to...
SLK-Purdue
Aug 09, 2021Luminary
.Is it safe for me to downgrade the Orbi firmwire back to my previous version? Anyone has done .downgrades before?
I tried and Netgear auto-update got me again the next night. Per this group there is no way to avoid the auto-update unless Netgear changes their policy/procedures. Good luck!!!
- FURRYe38Sep 17, 2021Guru - Experienced User
There ARE ways to avoid Orbi Auto update.
1. Host router upstream to block NGs services.
2. Telnet and change configuration versions with in telnet.
3. Tennet and change auto update service to not trigger.
SLK-Purdue wrote:
.Is it safe for me to downgrade the Orbi firmwire back to my previous version? Anyone has done .downgrades before?I tried and Netgear auto-update got me again the next night. Per this group there is no way to avoid the auto-update unless Netgear changes their policy/procedures. Good luck!!!
