AP2507
Feb 09, 2021Follower
Is it safe to update Orbi firmware with the Orbi app?
I have the Orbi RBK53v2 system (RBR50 & RBS50). Everything that I have read in this forum and in the manual, say when updating the firmware to always update the satellites first and then the rou...
Feb 09, 2021Guru - Experienced User
Use a web browser and PC or laptop and long into the RBRs web page to do any FW updates. Orbi app isn't recommended currently to update FW.
AP2507 wrote:I have the Orbi RBK53v2 system (RBR50 & RBS50).
Everything that I have read in this forum and in the manual, say when updating the firmware to always update the satellites first and then the router. No idea why I have to do this. I have therefore always done this manually in the past to be safe. When the 2.7.2.102 firmware came out, I clicked the update button in the app. It updated everything correctly.
So my question is, when you click update in the Orbi app, does the app know to update the satellites first and then the router? While looking at the lights cycling on the Orbis, it looked like everything updated at the same time.
- alokeprasadFeb 09, 2021Mentor
Any idea if the updates happen in the sequence "RBS first then RBR" when using the "Update All" button in the web interface?
- FURRYe38Feb 09, 2021Guru - Experienced User
The few times I've used the Update All button, I've seen the RBS being sent the FW first then the RBR starts processing soon after.
alokeprasad wrote:Any idea if the updates happen in the sequence "RBS first then RBR" when using the "Update All" button in the web interface?
