pbarham
Nov 21, 2020Apprentice
Is my 13-month-old RBR50 bricked?
Last night we had a brief power outage - for a couple of seconds. I lost internet connectivity and expected things to come back as normal after everything rebooted. However - my RBR50 did not. ...
- Nov 23, 2020
Well, after connecting to the internal serial console and fiddling around with the U-Boot loader for an hour I managed to unbrick my router and upload the latest RBR50-V2.7.1.60 firmware. Yay!!! :smileyvery-happy:
Serial port fun
The router had lost almost all of its configuration state - including it's MAC addresses, hardware id, model id, etc.
I needed to set these to back sensible values be able to bring up the TFTP loader and load/flash an image. (luckily the error message saying that the image file didn't macth the hardware ID told me what values I needed to configure!)
Then it took a couple of reboots to come up happy. Still had a bogus SSID and unknown passphrase (so the iPhone app was useless) - but at least I could log in on the LAN port and manually set thing up.
Now it seems to be happy I will see if I can find my configuration backup file ;-) (you know, the one you always make but have never tried restoring!)
Time for a beer!
pbarham
Nov 23, 2020Apprentice
Yes - I found some info in other threads about how to connect a serial line to the device and cause it to stop in the bootloader.
https://community.netgear.com/t5/Orbi/Force-RBR50-to-TFTP-for-un-brick/m-p/2010123#M107369
You need to open up the router (2 Torx T10 screws behind the label that surrounds the network ports
Then you need top remove the board from the case (the serial line is on the underside)
You connect up 3 wires to a a header on the board (using a $12 USB serial port adapter from amazon as per the PDF file here: https://www.snbforums.com/attachments/orbi-serial-port-pdf.23898/
You connect to your router using a terminal program on your laptop/pc. (see https://pbxbook.com/other/mac-tty.html)
Then when you power on the router you should see some log messages ...and after a few secons it will say :
Hit any key to stop autoboot: 2
You have 2 seconds to press a key and then it drops into the U-Boot command line.
Type 'help' to see a list of commands like:
(IPQ40xx) # help ? - alias for 'help' base - print or set address offset board_backhaul_passphrase_set- Set backhaul passphrase on board board_backhaul_passphrase_show- Show board_backhaul_passphrase board_backhaul_ssid_set- Set backhaul ssid on board board_backhaul_ssid_show- Show board_backhaul_ssid board_data_set- Set board data on board board_data_show- Show board_data board_hw_id_set- Set board_hw_id board_hw_id_show- Show board_hw_id board_model_id_set- Set board_model_id board_model_id_show- Show board_model_id board_parameters_set- Set WPS PIN code, Serial number, SSID, Passphrase, Board data, MAC address board_parameters_show- Show WPS PIN code, Serial number, SSID, Passphrase, MAC address. board_passphrase_set- Set passphrase on board board_passphrase_show- Show board_passphrase board_ssid_set- Set ssid on board board_ssid_show- Show board_ssid boot_partition_set- Set boot partition data on board boot_partition_show- Show boot partition bootdni - Check DNI image file. bootipq - bootipq from flash device bootipq2- bootipq from flash device bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol button_test- Test buttons calculate_address- Calculate the address of rootfs. check_dni_image- Check DNI image file. chpart - change active partition cmp - memory compare cp - memory copy crc32 - checksum calculation dhcp - boot image via network using DHCP/TFTP protocol dnisetenvmem- set environment variable from memory echo - echo args to console env - environment handling commands exit - exit script false - do nothing, unsuccessfully fdt - flattened device tree utility commands fuseipq - fuse QFPROM registers from memory fw_recovery- start tftp server to recovery dni firmware image. fw_recovery_second- start tftp server to recovery dni firmware image. go - start application at address 'addr' help - print command description/usage i2c - I2C sub-system iminfo - print header information for application image imxtract- extract a part of a multi-image incenv - increment environment variable ledctl - ledctl - Test LEDs loop - infinite loop on address range macset - Set ethernet MAC address macshow - Show ethernet MAC addresses md - memory display mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmc_loadn_dniimg- load dni firmware image from EMMC. mmcinfo - display MMC info mtdparts- define flash/nand partitions mtest - simple RAM read/write test mw - memory write (fill) nand - NAND sub-system nboot - boot from NAND device nm - memory modify (constant address) nmrp - start nmrp mechanism to upgrade firmware-image or string-table. pci - list and access PCI Configuration Space ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables reset - Perform RESET of the CPU reset_i2c- Reset I2C reset_i2c_to_blink- Reset I2C to blink reset_i2c_to_zero- Reset I2C rnset - set region number rnshow - Show Region Number on Board run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sf - SPI flash sub-system showvar - print local hushshell variables sleep - delay execution for some time smeminfo- print SMEM FLASH information snset - Set serial number source - run script from memory test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol true - do nothing, successfully uartrd - uartrd read from second UART uartwr - uartwr to second UART usb - USB sub-system usbboot - boot from USB device version - print monitor, compiler and linker version wpspinset- Set wpspin number
Since my router has lost all its config, including the ethernet MAC address, I needed to use `macset` before it would talk on the network. It came up with the IP address 192.168.1.250 (not 192.168.1.1 as every other article mentions!)
Then I tried to use `fw_recover` which starts a TFTP server that you can send a firmware image to.
From my Mac I started `tftp 192.168.1.250 69`
Then you need to select binary mode by using the `binary` command
Then you can try 'put firmware.img`
This failed the first two time - I got the folliwing errors:
HW ID on board: HW ID on image: 29765352+0+4000+512+2x2+2x2+4x4
and
MODEL ID on board: MODEL ID on image: RBR50 Firmware Image MODEL ID do not match Board model ID
I fixed these using the `board_hw_id_set` command and the `board_model_id_set` command.
I also set the serial number, SSID and passphrase to the values on the label on the bottom of the router - but it appears to ignore these!
Then the new firmware uploded and the router rebooted itself.
At this point I could point a web browser at http://192.168.1.250 (using the *wired* LAN interface) and it gave me the option to setup the router manually with a new SSID, password etc.
Note that the wireless interface came up with a bogus SSID of NETGEAR75 that I couldn't connect to . You need to use wired ethernet for the recovery process.
Let me know if you have any questions!
P/
Nov 23, 2020Guru - Experienced User
NICE. Thank you for this detailed process. I know for some it may not work for users that are not experienced, however for those that are, will be good.
Thank you.
