billForbes
Jun 14, 2022Aspirant
Is My CBR40 dying after only two years??
Over the last week, my CBR40 (+ one satellite) seems to be struggling. First, I'm no longer able to access via the orbi app (previous posts' suggested solutions haven't worked), only via browser. S...
billForbes
Jun 16, 2022Aspirant
I did a factory reset about 90 days ago and that worked. This time I was able to simply power down, unplug all ethernet cables, and then power up and plug them back in one by one. Everything is back to normal, but this feels indicative of a hardware fault in the physical router itself.
Jun 17, 2022Guru - Experienced User
What FW is loaded on the CBR and RBS?
What is the distance between the CBR and RBS?
What CAT# lan cable are you using? CAT6 is recommended.
- billForbesJun 19, 2022Aspirant
CBR40 is Orbi Firmware Version V2.5.0.28_1.0.8, CM Firmware Version V1.01.06
RBS is V2.5.1.16
its about 40 feet, however they're hard-wired together
yes, all CAT6
- FURRYe38Jun 20, 2022Guru - Experienced User
So only the Orbi app is not connecting?
There was a Orbi app issue seen about 30 days ago.
You may want to submit a bug report:
- billForbesJun 23, 2022Aspirant
there are two problems:
1. the physical router periodically stops working, solution seems to be to reboot, and then reseat/insert all the ethernet cables at the CBR40
2. the orbi app is not connecting - none of the referred suggestions are working
