Jroach
Jan 14, 2019Luminary
Is my internal performance OK
Looking to see if I am pushing my ORBI's to the limit or if I have another problem.
Problem: I have to run the Security Cameras at a lower res and lower fps that I would like.
Here is s snaps...
- Jan 14, 2019
Jroach wrote:
........... Same with the 2.4 vs 5, both drop frames.
One last thing to test! Packet drops can also be caused by the fragmentation thresholds. Default CTS/RTS Threshold is 2347 for both 2.4 and 5 GHz bands. Please try to change those something lower, start with 2307 and then try different values between this figure and 2347.
ekhalil
Jan 14, 2019Master
Here is s snapshot of my stats:
You have normal figures as I can see.
Do you have any specific issues that you see in your system?
Performance in Orbi is better measured by connected device and backhaul performance. Please measure the wired and wireless speeds that you get from your devices when connected individually in the network, this is an easy test to do.
Another test is when you have a number of devices are sending and receiving data at the same time, which is a test that is not easy to perform.
As Chuck_M mentioned, the CPU and RAM usage in the debug pages of the nodes give you good picture about your nodes' performance while doing the testing.
