Jroach's avatar
Jroach
Luminary
Jan 14, 2019
Is my internal performance OK
Looking to see if I am pushing my ORBI's to the limit or if I have another problem. Problem: I have to run the Security Cameras at a lower res and lower fps that I would like.   Here is s snaps...
  • ekhalil's avatar
    ekhalil
    Jan 14, 2019
    Jroach wrote:
    ...........  Same with the 2.4 vs 5, both drop frames.
    One last thing to test! Packet drops can also be caused by the fragmentation thresholds. Default CTS/RTS Threshold is 2347 for both 2.4 and 5 GHz bands. Please try to change those something lower, start with 2307 and then try different values between this figure and 2347.
