Jroach
Jan 14, 2019Luminary
Is my internal performance OK
Looking to see if I am pushing my ORBI's to the limit or if I have another problem.
Problem: I have to run the Security Cameras at a lower res and lower fps that I would like.
Here is s snaps...
- Jan 14, 2019
Jroach wrote:
........... Same with the 2.4 vs 5, both drop frames.
One last thing to test! Packet drops can also be caused by the fragmentation thresholds. Default CTS/RTS Threshold is 2347 for both 2.4 and 5 GHz bands. Please try to change those something lower, start with 2307 and then try different values between this figure and 2347.
Jan 14, 2019Guru - Experienced User
How many cameras do you have connected to the Orbi system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Here is s snapshot of my stats:
Jroach
Furrye38,
Thanks.
It's an internal network. No modem involved for the cameras. The more I increase the FPS or res the more dropped frames I get.
The problem happens with the base or the satellite so I don't think it's a satellite issue. The distance is about 15' as the crow flys.
- FURRYe38Jan 14, 2019Guru - Experienced User
15 feet between the Orbi router and satellite? if so, this is too close between them. 30 feet is recommended in between them to begin with depending upon building materials.
Jroach wrote:
Furrye38,
Thanks.
- JroachJan 14, 2019Luminary
Furrye38
It's 15' but its downstairs. What is the symptom if they are too close?
Thanks in advance
- FURRYe38Jan 15, 2019Guru - Experienced User
Would be degradation of performances. Having over lapping wifi that is too close can also cause interference problems between the base router and satellite. 30 feet in between is recommend to begin with for placement with the satellite(s). The router alone can cover up to 1100sq ft by itself depending on building materials.
Turn OFF the satellites and run some performance testings with just the router alone. Then turn on a satellite and test. Placement is key.
Jroach wrote:
Furrye38
Thanks in advance
