Jroach
Jan 14, 2019Luminary
Is my internal performance OK
Looking to see if I am pushing my ORBI's to the limit or if I have another problem.
Problem: I have to run the Security Cameras at a lower res and lower fps that I would like.
Here is s snaps...
- Jan 14, 2019
Jroach wrote:
........... Same with the 2.4 vs 5, both drop frames.
One last thing to test! Packet drops can also be caused by the fragmentation thresholds. Default CTS/RTS Threshold is 2347 for both 2.4 and 5 GHz bands. Please try to change those something lower, start with 2307 and then try different values between this figure and 2347.
Jroach
ekhali,
I had played around with teh 20/40 coexist when I first picked up the ORBI. I didn't find any difference in performance but I've tweaked a lot of things so its worth trying again. Same with the 2.4 vs 5, both drop frames.
WWM is set on.
Daisychain is set to off. I bring this up because I think that Netgear had me turn this off when I first bought the ORBI and I thought I saw a post that it was OK to turn it back on again.
ekhalil
Jan 14, 2019Master
- JroachJan 14, 2019Luminary
ekhalil,
Thanks for the advice.
I've changed it to 2307 and will test/monitor and report back.
Best.
- JroachJan 15, 2019Luminary
ekhalil,
Changing the RTS seems to have helped some. I've also found that the cameras have a "max bit rate" that I will also reduce to see what that does.
I'll report back
ekhalil, et al.
Is there a good tool that would help in PD? I was looking at Wifi Explorer (all mac house) to help.
