Jroach
Jan 14, 2019Luminary
Is my internal performance OK
Looking to see if I am pushing my ORBI's to the limit or if I have another problem.
Problem: I have to run the Security Cameras at a lower res and lower fps that I would like.
Here is s snaps...
- Jan 14, 2019
Jroach wrote:
........... Same with the 2.4 vs 5, both drop frames.
One last thing to test! Packet drops can also be caused by the fragmentation thresholds. Default CTS/RTS Threshold is 2347 for both 2.4 and 5 GHz bands. Please try to change those something lower, start with 2307 and then try different values between this figure and 2347.
Jroach
Chuck, thanks.
I get a 404 with "/debug"
Did I misunderstand your directions?
Under advance setting there are some stats for the Orbi but those are by the day, month, etc.
I'm trying to do some basic PD ie: is this a camera issue or am I throwing too much at the network.
randomousity
Jan 16, 2019Luminary
You have to go to 192.168.1.1/debug.htm to get to that page.
- JroachJan 16, 2019Luminary
randomousity,
Thanks. I started the capture....but where do I find the logs?
