Hoopla
Apr 17, 2019Follower
is my internet connection too slow?
My download speeds average38 mps///upload 2.4 // Latency 13 ms
have Orbi RBR50 and 1 sat. house is 2200 sq ft
can not kepp connection---constant buffering---???????
solutions??
Is the Orbi system operating in Router or AP mode?Are wired speeds good?
How are you testing speeds?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
solutions??
