Patgrad
Jun 25, 2021Aspirant
Is my Obi system broken
Excuse my ignorance but how do I know if my ORBI system is not functioning correctly? I have an ORBI RBS40 system that worked great till recently. System began lagging and devices were not connecting ...
Jun 26, 2021Guru - Experienced User
What modem/gateway are you connecting it to?
You posted in the Orbi LTE forum. do you have the LBR20 router?
Patgrad
Jun 26, 2021Aspirant
I have the RBR20 and not going to lie not sure how where I'm posting to. The modem is an Arris TM1602 from my internet provider Spectrum. When my phone does connect and I check my speeds they are 450+ download and 23 upload. Like I said was working without issue before but lately having trouble connecting to some devices
- plemansJun 27, 2021Guru - Experienced User
A couple things.
1. this would be the forum. https://community.netgear.com/t5/Orbi/bd-p/Orbi
for future reference.
2. did you try a simple factory reset and reinstall?
