npettersson
Aug 30, 2021Aspirant
Is my Orbi RBK50 supposed to be connected to my old ISP router ethernet port?
I thought the Orbi would replace my old router from my ISP? However, it's just connected to my old router ethernet port at the back. Feels like it should be connected straight to my fibre box. Se...
CrimpOn
Aug 30, 2021Guru - Experienced User
Yes, it should be connected directly to the fiber ONT (Optical Network Terminator). Remove the ISP router.
- npetterssonAug 30, 2021Aspirant
Thanks, but when I removed it there was no internet connection?
Should I start the wizard again from scratch?
Or are there some settings I can get from the ISP router while it is connected and then configure them in the Orbi?
- CrimpOnAug 30, 2021Guru - Experienced User
The obvious next step is to connect a computer (PC or laptop) directly to the Fiber unit with an ethernet cable. If it connects to the internet, then an Orbi should.
