rhester72
Oct 16, 2022Virtuoso
Is Orbi affected by latest (serious) WiFi vulnerability?
Not sure what the kernel version is, but the latest CVEs are unauthed and only require wifi framing to attack memory... https://www.reddit.com/r/linux/comments/y2w1sy/rce_vulnerabilities_in_linux...
Oct 16, 2022Guru - Experienced User
Not sure if thats specific to Linux wifi drivers or effects qualcomm. I believe Orbi uses qualcom for wifi.
If you are a NETGEAR customer with a security-related support concern, you can contact NETGEAR customer support at [email protected].
For all other issues, visit http://www.netgear.com/about/security/.
