cre8tivspirit
Oct 29, 2016Tutor
Is Orbi compatible with Honeywell RTH8500WF wifi thermostat?
I just purchased the Honeywell RTF8500WF wifi 7-day programmable thermostat and can't get it to connect to my home wifi. I keep getting a "connection failed No IP Address" message. I called Honeywell support and they had me turn on my phone hotspot and try to connect ot that. Worked great. Connected without any issues. Now I'm wondering if there is a problem with my Orbi recognizing the thermostat so it won't issue it an IP. Help please.
there seems to be an issue with a few of the IoT devices and connecting to the orbi esp if the sat is involved
try going to the orbi router gui and
advanced/advanced setup / wireless settings
and untick
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
and apply
then try connecting the thermostat again
see if that helps
pete
I never could get that model to work so I ended up buying an upgraded (i.e. more expensive) Honeywell thermostat and it connected flawlessly. Thanks for the help because Netgear support wasn't helpful at all.
