Errn94
Aug 01, 2019Follower
Is Orbi compatible with Vivint home security
I can’t seem to find an answer to this question. About a year ago I had Vivint home security and cameras installed. All was fine. About 6 months ago I switched my internet and tv to At&T. When they in...
Aug 01, 2019Guru - Experienced User
They say it works it should. One issue we see is that some device Mfrs only support there devcies on 2.4Ghz along with there setup software. Not realizing that Orbi is a single SSID MESH system that includes both 2.4Ghz and 5Ghz, this configurations seems to cause problems with 2.4Ghz Mfrs that don't take this into account with there setup software. Orbi does have an option to disable the 5Ghz radio temporarily so that user can get these 2.4Ghz only supporting devices connected.
It will be someting you'll need to try to see if it works.
