rkarthik_75
Jun 09, 2020Aspirant
Is ORBI RBK50 compatibile to Australia NBN?
Hi, I've purchased a modem (in Australia) with router and 1 satellite - Netgear ORBI RBK50 Tri-Band Wireless-AC3000 System PN RBK50-100AUS from Ebay. Seller says There are many types of NBN. If yo...
- Jun 10, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
rkarthik_75 wrote:Hi, I've purchased a modem (in Australia) with router and 1 satellite -
Netgear ORBI RBK50 Tri-Band Wireless-AC3000 System PN RBK50-100AUS from Ebay. Seller says There are many types of NBN. If you have a simple NBN modem box with just one network port to plug into, that should be fine ie FTTP, HFC etc. NOT FTTN. If you have a VDSL FTTN all in one device, it might not accept traffic to be routed via its modem out to the Internet
My question:
1. Does Netgear ORBI need to be connected directly to the phone line in the wall (and remove ISP provided NBN modem & router) OR does it have to be connected to the TP LINK NBN modem router (TPG provided-Archer VR1600v)?
2. Will it work at my house in my current NBN plan?
Look forward to your inputs.
Karthik
Jun 10, 2020Guru - Experienced User
Couple of options,
My question:
Karthik
- rkarthik_75Jun 11, 2020Aspirant
This seems to be a good option - disabling the router or reconfiguringh NBN modem/router settings to detect and allow IP passthrough to Netgear. Thanks FURRYe38
Update: My ISP is TPG and their L1 tech support today was so persistent that it is Netgear's problem, not compatible to any other model etc. I had to threaten to cancel their contract which has prompted them to escalate to a senior tech person. Hopefully they'll assign
- michaelkenwardJun 11, 2020Guru - Experienced User
Of the three options, I'd rate this as the least satisfactory, and hardest to set up and maintain. It is suitable only if the two better options won't work. (Some ISP modem/routers won't play ball.) Why faff around with two devices when you really need to tweak only the modem./router?
The best option is probably "bridge mode" for the modem/router followed by wireless access point (AP) mode for the Orbi.
A lot of people go for AP mode because they have routers with better features and they want the Orbi for its wifi advantages.
In your case, I'd say that the Orbi would be a better router than your modem/router, a pretty basic box.
It is a pity that some websites describe the Archer VR1600v as a "modem". It is a modem/router. But unlike some ISP boxes it can work in bridge (modem only) mode. It seems to be easily changed.
How to turn on bridge mode on the TP Link 1600v - TPG Community
Then there is this bit:
As various discussions have shown, TPG tech support is famously ignorant about how its own network operates and how to get third party hardware to play nicely.
Solved: Re: VLAN tagging for TPG NBN - NETGEAR Communities
There are other messages on the same theme around here.
Search - NETGEAR Communities – TPG NBN
A good source of local incormation is here:
- rkarthik_75Jun 12, 2020AspirantActually it worked without explicitly attempting any of the three options. I was in a call with TPG senior technician and he confirmed nothing was done on their side too. All I did was update the firmware again and it worked. Strange and could have worked the 1st time! There were compatibility issues with Orbi with TP link modem but confirming it's working fine without actually doing any troubleshooting. So all good now michaelkenward
- FURRYe38Jun 11, 2020Guru - Experienced User
Hopefuylly you can get yours working well. michaelkenward has provides some great resources to check out to help you.
Let us know how it turns out.
rkarthik_75 wrote:This seems to be a good option - disabling the router or reconfiguringh NBN modem/router settings to detect and allow IP passthrough to Netgear. Thanks FURRYe38
- rkarthik_75Jun 12, 2020AspirantThanks mate FURRYe38
All good now and taken your post as a solution. The Orbi app shows internet is offline in the dashboard when it's working, but that's for a different post. Cheers
