rkarthik_75
Jun 09, 2020Aspirant
Is ORBI RBK50 compatibile to Australia NBN?
Hi, I've purchased a modem (in Australia) with router and 1 satellite - Netgear ORBI RBK50 Tri-Band Wireless-AC3000 System PN RBK50-100AUS from Ebay. Seller says There are many types of NBN. If yo...
- Jun 10, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
rkarthik_75 wrote:Hi, I've purchased a modem (in Australia) with router and 1 satellite -
Netgear ORBI RBK50 Tri-Band Wireless-AC3000 System PN RBK50-100AUS from Ebay. Seller says There are many types of NBN. If you have a simple NBN modem box with just one network port to plug into, that should be fine ie FTTP, HFC etc. NOT FTTN. If you have a VDSL FTTN all in one device, it might not accept traffic to be routed via its modem out to the Internet
My question:
1. Does Netgear ORBI need to be connected directly to the phone line in the wall (and remove ISP provided NBN modem & router) OR does it have to be connected to the TP LINK NBN modem router (TPG provided-Archer VR1600v)?
2. Will it work at my house in my current NBN plan?
Look forward to your inputs.
Karthik
rkarthik_75
Jun 11, 2020Aspirant
This seems to be a good option - disabling the router or reconfiguringh NBN modem/router settings to detect and allow IP passthrough to Netgear. Thanks FURRYe38
Update: My ISP is TPG and their L1 tech support today was so persistent that it is Netgear's problem, not compatible to any other model etc. I had to threaten to cancel their contract which has prompted them to escalate to a senior tech person. Hopefully they'll assign
Jun 11, 2020Guru - Experienced User
Hopefuylly you can get yours working well. michaelkenward has provides some great resources to check out to help you.
Let us know how it turns out.
rkarthik_75 wrote:This seems to be a good option - disabling the router or reconfiguringh NBN modem/router settings to detect and allow IP passthrough to Netgear. Thanks FURRYe38
- rkarthik_75Jun 12, 2020AspirantThanks mate FURRYe38
All good now and taken your post as a solution. The Orbi app shows internet is offline in the dashboard when it's working, but that's for a different post. Cheers- FURRYe38Jun 13, 2020Guru - Experienced User
Yes, I'm seeing same issue with Orbi app and my RBR50 It shows off line. Please post about the Orbi app issue in the Orbi app forum.
Enjoy. :smileywink:
