Monterey_JackG's avatar
Jan 15, 2020
Is Orbi RBR20 Compatible with Chromecast?
Have tried to connect Google Chromecast to my RBR20 Orbi.  Failed.  Worked with Gooble Chromecast support over 2-day period.  Failed.  Researched Netgear Community knowledge base, and sent email to Netgear support.... Case#42184503 ... awaiting a response.  Note:  Using the Orbi and Google Home apps on android phone.
Without getting into the minutiae of my circumstances, maybe I should ask if anyone successfully connected Chromecast to Orbi RBR20?  If they are not compatible, then it's time to quit.  Otherwise, if anyone has been successful, please advise with suggestions/recommendations.
1 Reply
  • FURRYe38's avatar
    What do you mean by "Failed"?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
