Q80fahad
Jun 01, 2019Aspirant
is orbi suitable for 3 story building
Hi, I live in 3 story building. Not from made from wood like most homes in the US. I have Ethernet points in all 3 floors. Each floor is 5380 ft square. Whats my best option?
- Jun 01, 2019
Q80fahad wrote:
Great but will 5 or 6 satellite node work? I read that Orb only work with 3 ?is there specific configuration or setup I should consider?Yes, there is no "technical" limit on the number of Satellites. The recommended 3 Satellites limit is just to control the interference between the nodes, so if you will have the Satellites quite far away from each other then you will not need to bother about this limit.
There are people in this forum who reported using more than 9 Satellites with no issues.
Jun 01, 2019Guru - Experienced User
Yes should work well. Depending on buiding materials and size, you may need two satellites instead of 1. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- Q80fahadJun 01, 2019AspirantMy building wall is made if brick and mortar and floors are concrete and steel?
