Ahmed92
Dec 11, 2018Aspirant
Is RBK 50 still having problem with backhaul
Can anyone confirm that RBK50 works good with backhaul without any disconnecting. Thanks
ekhalil
Dec 12, 2018Master
I have wired backhaul and it’s working perfectly well.
- Ahmed92Dec 12, 2018AspirantI was having RBK 50 before 6 months when i connected it through wire backhaul it was disconnecting every 5 min so i have returned it
- ekhalilDec 12, 2018MasterI think that the latest software 2.2.1.210 fixed the issues related to wired backhaul.
I had wired backhaul since almost 2 months (since the release of .210 SW) and it’s rock solid. :) - FURRYe38Dec 13, 2018Guru - Experienced User
Theres seems to be a process to setting up wired backhaul that seems to help when using wired backhaul with satellites.
