wbaxter02
May 29, 2020Aspirant
Is RBS10 compatible with RBR50
Is the RBS10 compatible with RBR50?
wbaxter02
Exactly, other satellites seem way over priced
CrimpOn
May 29, 2020Guru - Experienced User
More information:
Notice the Product Data Sheet for the RBS20 "What do I need for Orbi to work" says "Requires RBR20, RBR40, RBR50 Sold separately"
https://www.netgear.com/images/datasheet/orbi/RBS20.pdf
Whereas the Product Data Sheet for the RBS10 says "Existing Orbi router RBR10"
https://www.netgear.com/support/product/rbs10.aspx#docs
Not exactly "In your face", but pretty definitive.
