RBK13's avatar
RBK13
IS RBS50Y compatible with RBR10??
I asked this question 3 months ago, the answer from Netgear support was "Yes". I bought today a RBS50Yv2 and I'm trying to install it unsucessfully, no way to connect it to the RBR10, after trying t...
  • plemans's avatar
    Feb 14, 2022
    Compatible in extender mode, yes.
    compatible in orbi mode. No. the RBK10 system is a dual band system while the RBS50Y is a triband system.
    It should work fine in extender mode. Devices will still roam to it and it'll function as part of the mesh. its just not controlled via the app the same way.
